Terryallan
Sep 22, 2014Explorer II
Easy to do as mentioned. pump pink thru the lines with the pump. Only thing I didn't see was what to do about the city water connector.
After you have pumped the pink thru the lines. Go outside to the city water connection. Remove the cover. Stand to one side. Do NOT stand infront of the connection. Take a screw driver, and gently push in the little button if it has one. If not, then gently push in the center of the connection, until the valve releases, and lets the water, and then pink come out, and it WILL come out in a hurry.
44,068 PostsLatest Activity: Jun 10, 2026
