- Is the control box ripped out? I think it is the two blue wires or white with blue stripe to twist together and the furnace will run. Possibly go down to a hardware store and get a heat only thermostat to control the heat function.
- Chris_BryantExplorer II
wildtoad wrote:
Isn’t it already wired to control the furnace?
On his DuoTherm, the thermostat controls the air conditioner, which controls the furnace.
There’s no way for his thermostat to directly work the furnace. - wildtoadExplorer IIIsn’t it already wired to control the furnace?
- Chris_BryantExplorer IIWhat he said. Identify the two wires from the furnace, hook them to two wires of your choice in the wall t-stat wires, then get a simple furnace only t-stat and hook it up.
- LwiddisNomadWon't you eventually replace the A/C? If so, just do it right...and once.
- Flute_ManExplorerYou would probably have to use a separate thermostat and you would need the interface wiring for the furnace so you would know which wires are which.
Jerry Parr
