420green
Feb 08, 2016Explorer
MFL wrote:SouthpawHD wrote:
I believe it was a 5.7L during that time frame.
According to the 2001 Trailer Life guide, it appears it could tow up to 6,600 pounds (also as little as around 5,100). Obviously some variables there that need to be cleared up first in order to figure its actual towing capability.
And yes, if the van can tow this, you NEED a WD hitch.
Yes, the OPs numbers indicate a 5.7L. If the TV is in good condition, it may handle that trailer, with the help of a WD hitch.
Jerry
This is dry weight and those specs came from my vin to spec sheet. They should be very accurate. I just honestly don't understand a lot of the terms .
44,066 PostsLatest Activity: Apr 10, 2026
