ksnider74's avatar
ksnider74
Can my truck tow this?
So like any other new person that's bought a travel trailer I probably have put the cart before the horse. So ultimately the question is can I tow this...
I have a 2019 GMC Sierra Elevation DC 4x4 with the tow package and the L84 engine and a 3.23 gear ratio. The limitations are
9400lb Towing capacity
7000lb gvwr
15000 GCWR
3800 GAWR RR
940 tongue weight
The trailer I bought was a 2020 Venture Sport Trek 322VRL with
1010 dry hitch weight
7580 dry weight
8820 loaded weight
So I know that the owners manual for the truck gives specs and limitations and states any trailer must have a WDH and then shows 50%? So can I tow thing or what?
Thank you all in advance and will appreciate any feedback.
    7000lb gvwr
    15000 GCWR
    3800 GAWR RR
    940 tongue weight
    7580 dry weight
    8820 loaded weight
    You were over at hello.
    The trailer, at a loaded weight of 8820 should put about 1200 on the hitch when ready for the road. Plus add 100lbs or so for the WDH.
    The trailer itself will be a balancing act, empty weight of 7500, add 40 for a battery, 60 for propane, then figure what you will for water as well as your possessions. For a 32' trailer pack light. It can be done, but you dont have a lot of extra capacity. 50 gallons of water alone will eat 400 of the remaining 1000 pounds of available capacity.
