Suspect your numbers and the best thing to do is to go out and actually
weigh your truck, axle by axle, both fully loaded ready to go and empty
Comments in red embedded below
zackyboy3rs wrote:
This is the one I want. Before you decide please realize that we travel with ONLY 10 gallons of water (max) & use it to flush toilet when we stop.
Tv - 6000 lbs wt. / 3250 payload/ 10000 towing max./ 16000 GVWR
Suspect the 6,000 is the published 'curb' for your 2500HD. 'Curb' is
the 'stripper' model and no options...like the Duramax/Allison which
will add several hundred pounds, min, to that curb of 6K. Even with
the small block 6L, it will weigh more than the 'curb', if you have
any options like: AC, power door/window/seat, upgrade interior, etc, etc
Suspect the 16,000 is the GCWR (gross combined weight rating)...
Note that if you have over sized (larger dia) tires...that 3.73 is
effectively changed to a lower numeric, which lessens the tow
ratings.
Payload is typically based on a 'curb' weight, so it will be less
by the weight of all the options
5th wheel specs - 7547 dry/ 1035 hitch/ 10800 gvrw
The 'dry' is the 'curb' for the TV. No options and suspect you already
knew that with your comment of limiting your water
That means I could add about 3200 lbs of water, cloths, food...etc.? Correct
Only if you do have a 'curb' weight truck...again, best to go out
and actually weigh your truck, axle by axle.
That is the only way to know where you are in reference to your trucks
ratings
I mainly camp in eastern NC but MIGHT travel to mountains 1 a year. Fancy Gap, VA & Black mountain, N C are the biggest obstacles.
That 'might' becomes a reality all too often and I refer to those instances
as "when Mr Murphy crosses your path"
Can my TW handle it? If so, what hitch would you recommend?
If you are only looking for a confirmation, then you will get tons of
them and note that there is only one person responsible for the setup
and that is the driver. Maybe not even you, the OP, but someone else
driving it
I do not normally say yes or no, but provide the information to
figure it out yourself, as again, there is only person responsible
for the setup..the driver
Thanks!
