dodge_guy
Apr 01, 2016Explorer II
PUCampin wrote:Jebby14 wrote:
APRIL FOOLS!
If it is, then the OP picked the wrong vehicle to joke about, because the only reason the non-tow package Explorer was rated for 3500 was the class 2 hitch, which the OP shows was remedied by a aftermarket class 3/4. The only things added in the factory towing package was the class 3/4 hitch and 7 pin plug (and the v6 gets a slight axle change from 3.55 to 3.73) :)
X2! The explorer was only rated to 3500 due to the class II hitch. If you had the classIII/IV hitch then you would be OK. No reason that he Explorer the OP is talking about can't tow the trailer he has listed. I towed a 5000lb GVWR TT with a 95 Explorer with a Class III hitch and had no issues. As long as the OP is using a WD hitch he will do just fine!
44,056 PostsLatest Activity: May 04, 2014
