enblethen
Apr 09, 2015Nomad
You need to locate the wire that goes to the furnace. Might be the same color in panel and furnace.
Then look where it is attached on DC buss work.
If not the same color or you can't find it, Use a test light to verify whether there is power at the furnace. If power is present, go to DC panel and start removing fuses until power at the furnace goes away. then mark it.
