thehippie
Mar 05, 2015Explorer
Can this be removed?
What is this metal inverted triangle under the trailer.? Can it be removed or cut away? It keeps on hitting the driveway when i back up on my driveway.
Can I remove it ?
Can I remove it ?
WyoTraveler wrote:It's normal then when it rubs the ground? I'm a newbie with travel trailers.
Yup, that is what it is for. It rubs the ground like sled runners so you don't damage the rear of the trailer when going up or down steep slopes.
kaydeejay wrote:How to raise the axles? Looks like a lot of work though?
It's a skid to prevent more critical parts of the trailer from hitting the driveway!
Remove it and you may damage something else.
Can you lower the front of the trailer while entering the driveway, or raise the axles?
