Second Chance wrote:
A gentleman who spent 40 years with a major tire manufacturer told me that they can be patched (not plugged) - but, for safety, it reduces the load rating by one letter; e.g., if it's a load range E tire, patched it becomes a load range D tire.
Rob
I think I would need to know what positions that gentleman had in the tire industry.
Lifetime I have used a lot of tires though few where ST. I have never reduced the load I carried because of patch.
If the tire got a hole in the first tread I would plug from inside then patch. When due for 2nd re-cap I would trade the patched carcass let somebody else take the chance.
Tire engineer/designer. He sure knew his chemistry, too.
Rob
It's generally accepted that a tire can be repaired as long as the puncture is not in the shoulder or sidewall area. Ideally with a "Stem Repair" NOT PLUG. The stem's are cured rubber coated with a chemical vulcanizing material that will bond with the tire. Stem, once placed in hole is then cut off flush with the inside liner and covered with a patch. Many times, if hole is straight through tread, the shop will use a Stem/Patch combination repair where both are in a single unit and can be installed in a single operation.
A repair like this will restore the tire to it's original load rating but NOT SPEED RATING. It's recommended by all tire Mfr's that a repaired tire be downrated one SPEED rating, not load rating.
A proper repair on any tire, car, Light Truck, Semi, or ST trailer tire will last for the remaining life of the tire.
FWIW, I spend 17 years of my career teaching proper tire repair to employees of a 500+ store tire "chain". We used the training and materials of Tech Inc. a large tire repair material manufacturer.
