Gsragtop's avatar
Gsragtop
Can you have too large of a trans cooler ??
So I was walking out of my local wrecking yard, when I saw a truck with a nice aftermarket trans cooler just sitting there (front grill removed, easy access).. So I pulled it off to add to my kia.. Then I thought maybe it's too large ?? Could that cause issues with the trans as well ??
Also,on the truck it was mounted in front of the AC condenser. While this is an easy place to put it, would it not effect the AC performance ??
Thanks
Josh
  • Many newer vehicles won't let the torque converter go into lockup until a minimum temperature is reached. Probably not an issue in SC.
  • It's possible but doubtful. The only time it would be too big is iff you were unloaded and the trans temp never got up to 140 degrees. In that case the fluid wouldn't burn off moisture and may get contaminated.
  • Josh, on my 07 GMC Sierra the trans cooler is mounted in front of the A/C cooler which is in front of the radiator. I think most vehicles are that way. As to the oversize, I have an oversize one on my truck. Do i need it in the cooler weather, NO. Do I need it in the summer when towing up long upgrade and backing down on long downgrades, Yes. Maybe you need one maybe you don't. You need to research it more. How is your TV doing now?
