PUCampin
May 27, 2016Explorer
One of the benefits of wider ratio transmissions and many gears is they negate the requirement for multiple rear axle ratios.
1st gear example Old 4spd
Dodge 48RE 2.45 x 3.73 = 9.13 ; 2.45 x 4.10 = 10.045 ; 2.45 x 4.56 = 11.72
Ford 4R100 2.71 x 3.73 = 10.10 ; 2.71 x 4.10 = 11.11 ; 2.71 x 4.56 = 12.36
GM 4L80E 2.48 so similar to Dodge
New 6spd
Dodge Aisin 3.75 x 3.42 = 12.825 ; 3.75 x 3.73 = 13.99
Ford 6R140 3.97 x 3.42 = 13.58 ; 3.97 x 3.73 = 14.81
So you can see, even with a 3.42, the new 6spds have deeper gears than the old 4spds did even with 4.56!! The other aspect I love about the Ford 6sp is 4th is not 1:1, but 1.15:1 effectively making towing in direct like if you had a lower rear end turning that 3.42 into a 3.93
The 6r75 in my Expy is 4.17:1 1st and has 3.73 (standard on the EL) for a 1st gear crawl ratio of 15.55. It shifts out of 1st at 15mph. I love it! No worry about stalling going up a steep hill!
New 6spd
44,066 PostsLatest Activity: Apr 16, 2026
