KZowner49 wrote:
My regulator does not appear to have a green flag in window, just a red one that disappears when I open the valve on either cylinder, so I don't think the pigtails are bad. Like I said earlier we have camped at KOA 4 times and all the appliances work fine. Its just when we are at the storage place with no hookups we can't get propane to work. The guy from the dealership thought the hot Texas air may be heating up the air in the propane line and putting too much back pressure for the propane to flow. And when we drive the trailer for an hour to the KOA the propane pipe cools down so maybe that is why it seems to work there. Problem is wife wants me to get refrigerator cooled down before we leave site.
Try this.
Turn on one of the tanks (slowly turn the valve).
Red "flag" should go away on the change over.
Leave tank on.
Go to your stove.
Take a manual lighter and light it.
Now, turn on one of your stove burners and place lighter flame beside the burner.
You should initially see the flame get "pushed" from the burner.
If no push then you have an issue with the regulator.
If you get a push, keep the manual lighter lit and held close to stove burner.
AND WAIT.
In this case you have AIR in the gas line and depending on the size and distance of the line it can take several minutes to get propane.
Once the air is purged, the stove burner will start to light.
Once the stove burner is lit, the rest of your appliances now should work.
Believe it or not, air can and does enter your gas lines when the propane cylinders are turned off for some time between uses.
If the cylinders are turned off for a long time you will have to purge the air out of the propane lines each time you startup.
Never have figured that one out but after owning several RVs which have done the same thing I suspect it is normal.. I have even pressure tested the lines on my current TT to make sure it isn't leaking.
Because of this, I never leave my cylinders turned on when not camping, hate to waste propane..
