tvman44
Jul 09, 2016Explorer
Another good idea is to get into your breaker panel and make sure all connection are tight as they have a tendency to loosen up in a RV and will cause extra heat. A fan is a good idea as the manufactures usually sandwich the panel in a small enclosed space causing heat build up. In real hot weather I usually leave the wood door on the panel compartment open to allow some heat escape. I have plans to install a fan, but I only think about it when I need it and we seldom use our RV in the real hot weather. I prefer camping say October thru June then stay home July thru September.
