Sir_Buffalo's avatar
Sir_Buffalo
cannot maintain electric?
Continue to pop circuit breaker. First three days no issues. Day four one occurrence . Day five late afternoon through the night - had to reset about 4 or 5 times? Any recommendations?
  • You don't post enough information to give you an answer.
    But, when we consistently pop breakers, we turn off the electric water heater. This usually solves the problem. People often forget it is on and then run the microwave and a/c or two other large load appliances, overloading the system.
  • We're going to need more info. Line voltage, how many things are being run on electric, etc
  • I'm assuming this is the main (30A) breaker? It will probably keep opening as it gets hot (weaker).
    Has this happened before?
    Is there low voltage (<105 volts) where you're plugged in?
    Is the shorepower breaker opening also?
    Do you have another power pedestal, generator or other source of power?
