DutchmenSport
Apr 20, 2017Explorer
I've been using the GoodSam portal, and been logging out after every session I use. When I came back, I have to enter my user ID and password again. I started doing this because I was getting the "I am not a robot" page, which I could never successfully get past. Found out by logging out, shutting down the browser and taking the time to log back in the next time has taken care of this (for a while anyway). I had a previous post for this problem, so either I've found a good work around, or it's been fixed, because I've not encountered it for a few days now.
I work in IT, I'm a software tester, and it's not uncommon at all for the developers to fix a problem "over here" and it breaks something "over there". So, who knows what's going on.
I suggest using GoodSam.com, select the tab "community", in the drop down, select "Forums" and your in. Log out after each session. Shut your browser (occasionally clear your cookies and cashe) and see if that helps.
Good luck.
Good luck.
