- gboppExplorerDo you have a PER CENT symbol in the info you are trying to post?
- bka0721Explorer II
jefe 4x4 wrote:
tried the clicky to no avail. in fact, tried 3 times to answer here with no success until now. Now the 3 portals are not even posting a message for me. Is it something I said?
jefe
Well, Jefe, I suspect you are having the issue due to the factor you are no longer able to cross your toes, turn counter clockwise, 6 times at a rotational rate equivalent of 3 rotations per minute. So in other words, you’re screwed.
b
ps. I posted this by using the Clicky in the earlier post. - jefe_4x4Explorertried the clicky to no avail. in fact, tried 3 times to answer here with no success until now. Now the 3 portals are not even posting a message for me. Is it something I said?
jefe - bka0721Explorer IILots of options but I find the best result is using Trailer Life's Portal. Try this Clicky;
Clicky
I find what Drew shared to be the most common reason the posts won't load, some sort of script error. A better software would correct this error.
Yeah, don't keep us in suspense too long now.
b - Buzzcut1Nomad II
wnjj wrote:
Buzzcut1 wrote:
different portal, yeah sure like Woodalls and when it gets shut down poof goes your trip reports with it. My Grand Teton TR is gone for good
usually I find that error is from long photo URls redo them using tinyurl and it should go through
Not gone. Just the link from Woodalls is. Here's your Teton TR: http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28980662.cfm
ah so its the trip report sticky links that need to be changed same issue with my sequoia TR
thanks - wnjjExplorer II
Not gone. Just the link from Woodalls is. Here's your Teton TR: http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28980662.cfm - PatrickA51ExplorerDon't feel too bad everything I get from RV.net goes in my Bulk File.
- anutamiExplorer IIISalivating at the suspense...
- Buzzcut1Nomad IIdifferent portal, yeah sure like Woodalls and when it gets shut down poof goes your trip reports with it. My Grand Teton TR is gone for good
usually I find that error is from long photo URls redo them using tinyurl and it should go through - jefe_4x4ExplorerWoodalls says,
Your connection is not private Attackers might be trying to steal your information from forums.woodalls.com
I tried to download it to RV.net forum.
jefe
