davisenvy's avatar
davisenvy
Can't figure out scare lights
I have a new to me 2013 StarCraft 2787bh. We took it out for the first time this weekend. Everything went great except I couldn't figure out how to turn on the scare lights. There is a light switch next to the master bed and there is another light switch in the main switch panel that doesn't do anything. Are these the switches and they just don't work? I have two scare lights, one on the front passenger and one on the rear driver. What am I missing
  • My indoor power is on and the switch by the bed doesn't do anything. In the main control panel I have 4 switches. One does the main lights, one does the outside yellow light, one is the awning, and the 4th doesn't do anything either. Does your 1 switch control both lights?
  • Our scare light switch in our 2013 Starcraft is right next to the bed. We have 2 "power" switches inside the main control panel, one operates the power to the inside of the tt, the other operates the outdoor lights (not including the scare lights) The scare lights should operate as long as you have indoor power on.
  • RoyB's avatar
    RoyB
    Explorer III
    My scare lights for my fifth wheel are mounted on the rear sides of the trailer. The switch for them was near the rear window setup not near my entrance door here I would have expected them to be located.
    I guess the thought here is to check out the noise you just heard by looking out the rear window ???
    Probably the only time I would ever use mine would be backing in somewhere...
    Roy Ken
