rbpru
Oct 23, 2017Explorer II
I am with the group that owns a TT with the drain pipes capped and hidden behind the tires. I did not even know about then the first time I winterized.
They are a pain, I flush the antifreeze through the TT faucets, then I have to crawl under and open the drain pipe caps enough to bleed out the water till the antifreeze flows. It usually flows down my arm. :(
Some day I am going to replace them with valves.
Good Luck
Good Luck
