bobndot
Jun 13, 2013Explorer III
Charge the battery to full , then try it.
Jumping the dead battery might not work . If you disconnect the dead camper battery then use the good battery to try it...that might work .
Lance 2003 Owner's Manual, page 8 reads:
"Do not use the electric jacks to raise or lower the camper using only 120-volt power. The converter's charger will be damaged if the jacks are operated with 120-volt power through the 12-volt converter without an automotive battery or with a low battery. A well charged battery in good condition is required."
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26724768.cfm
44,059 PostsLatest Activity: Mar 17, 2026
