JD5150
Jan 07, 2020Explorer
I do not own one, but I did look long and hard at them. Only way I would buy one is to buy it as a shell model. That way I could build the inside my own way. I would build it so everything is portable or easy to take out of it. Reason for this, so it would be easy to take the inside wall panel off to dry it out if a leak happen. If a leak happens there is no way to dry out the wall cavity in a hurry with all the stuff they put in it. Rot and mold will start to grow with trapped moisture inside the walls or ceiling. With the insulation they use even makes it harder to get it dry. I would be checking my seals and inside the camper weekly, after a rain storm, snow melt and after every trip to make sure it's all good.
I would also get it without the front cab window. It leaks from the beginning. They tell you that on their website. Driving in the rain when the leak happens
44,071 PostsLatest Activity: Aug 30, 2026
