Lynnmor wrote:
ShinerBock wrote:
Lynnmor wrote:
Name a few people that said that.
What do you use for a tow vehicle?
You were one of them that stated premium fuel is required when towing with an an Ecoboost truck.
I currently use a Ram 2500 CTD as a tow vehicle. What does that have to do with anything?
I did repeatedly copy & paste fuel information from the Ford owners manual without embellishment, you choose to disregard what it says, Here it is once again:
For best overall vehicle and engine performance, premium fuel with an octane rating of 91 or higher is recommended. The performance gained by using premium fuel is most noticeable in hot weather as well as other conditions, for example when towing a trailer.
You want comments from only those that own a Ecoboost while you use a Ram diesel and comment on a Ford. :S
This is actually the full quote:
"Your vehicle is designed to operate on regular unleaded gasoline with a minimum pump (R+M)/2 octane rating of 87.
Some fuel stations, particularly those in high altitude areas, offer fuels posted as regular unleaded gasoline with an octane rating below 87. The use of these fuels could result in engine damage that will not be covered by the vehicle warranty.
For best overall vehicle and engine performance, premium fuel with an octane rating of 91 or higher is recommended. The performance gained by using premium fuel is most noticeable in hot weather as well as other conditions, for example when towing a trailer. See Towing. "
So premium is recommended not required for full performance. I think everyone is wrapped up on being correct instead of accurate. The standard ecoboost was designed to operate on regular 87 octane.
