Gdetrailer
Nov 11, 2017Explorer III
temccarthy1 wrote:oyarsa wrote:
We are heading on our maiden voyage!
I have a 2012 Toyota Sequioa pulling a 2017 Bullet 247BHSWE. I of course have a brake controller installed, but I'm struggling with getting it properly adjusted. The car is jerking a lot when I let off the breaks. This is particularly annoying in town. If I lower the gain, I can get rid of the jerking, but at that low the trailer breaks don't feel like they're doing much. If I just use the paddle it doesn't slow us down very well. I've tried adjusting the sync, which seemed to help, but only modestly.
Should I expect it to be smooth when releasing the break, or just get used to the jerking?
The jerking you feel is normal in slow moving heavy traffic when you are constantly stopping and starting at lights. Just dial down your controller until it stops the jerking movement(1-3). It will not be a stopping problem when you are generally going 25 mph or less. When you get back to open areas and highway speeds, just dial the controller back up to mid range (5-7). It will make the stop starts much more comfortable! Try it! Works for me every time! I read about it on a blog like this! Hope it helps!
NO, NO, NO!
That jerking is not "normal" at all IF you have a GOOD QUALITY BRAKE CONTROLLER!
The jerking comes from CHEAP INFERIOR ENTRY LEVEL CONTROLLERS which are no better than turning a light switch on and off.
I made ONE trip with a cheap time based controller and quickly decided that spending MORE on the BEST controller I could find was number one priority.
I studied long and hard and decided on the Jordan Ultima 2020 which used a stainless aircraft wire connected from the brake pedal to the controller.. That cable actuated a sensor inside the controller which controlled the output instead of relying on timers, micro computers and firmware..
Skipped right over the all of the simulated controllers like the Voyager, P2 and P3 series and went straight to something the DIRECTLY interfaced to the vehicle.
The result is a set and forget controller, I NEVER had to readjust for ANY different driving condition.
That feature alone I can say HAS saved my bacon several times when driving 65 mph and having DEER cross in front of me :E , under emergency situations like that you DO NOT HAVE TIME to fiddle with a brake controller settings!
At that time I bought the Jordans they only cost a mere $10 more than a P2 but to me that extra $10 saved me THOUSANDS of dollars in damages TWICE!
Sadly, Jordan is out of business and finding direct controllers is a difficult and expensive task..
There is only one now days and it connects via the OBDII diagnostic port of your vehicle, it is expensive at around $325 but it WILL operate as smooth as a IBC (factory integrated controller).
DIRECLINK BRAKE CONTROLLER
If you don't wish to spend that kind of money, then at least go to a P3, that is the most advanced inertia controller on the market and should result in a fairly smooth drive without the need for constant baby sitting of the controller.
