Sort By
- stevenalNomad IITongue weight? Assuming the weight of the added metal is negligible in relation to the overall weight, the added lever length will work to decrease tongue weight. If the trailer in question isn't flipping end over end, the sum of the moments is always equal to zero. If it should decrease too much, you may be able to adjust the axle(s) position(s) to compensate.
- time2retireExplorerI made a 30", 3/16" thk. 2"x 2" piece of square steel tube with a hole for the ball and one for the pin. It fits right in the factory hitch. It was less than $30 and is stronger than the trailer tongue. My camper sticks 16" out of the bed of the truck. It works great albeit I'm only pulling a 14' aluminum boat. It was an "engineering marvel" LOL.
- zcookiemonstarExplorerThanks everyone for your replies.
burningman wrote:
Seems many who replied misunderstood the question. This isn't about hitch extensions.
No, a longer trailer tongue will not make the trailer tow "wonky', it'll make it tow straighter and more stable.
A longer tongue will not increase tongue weight. And depending on your setup, it takes a pretty extreme angle to hit the camper.
I stretched my trailer tongue four feet. It has plenty of clearance below the camper. It works great, and is much safer and better than putting the hitch four feet behind the truck.
You don't have to install and remove any heavy junk every time you load or unload the camper.
Nobody pulls heavy trailers on four foot hitch extensions without a camper on their truck, ever. It's obvious why not. Its no different when you do have a camper on. People do it because its the store-bought, bolt-on solution and stretching a trailer tongue is custom work.
Wow I am so glad I asked this question. I didn't even think about my sewer line under the rear of the camper. In the right or wrong situation I think that tongue would hit. Thanks Burningman you always seem to be able to understand my poor writing and answer my questions. Kayteg1 wrote:
One thing to mention - truck long stinger not only adds like 200lb to the rear,
My extension does not weigh 200 lbs. Even the longest Torklift extension doesn't weight that much.Kayteg1 wrote:
Dletabravo completely misunderstood why the truck in picture broke.
No, I didn't misunderstand anything about that busted truck. That issue has been hashed and rehashed multiple times on many forums dating back to when the guy broke his first truck 5+ years ago.- wnjjExplorer II
You correct on most points but you're leaving out a few other reasons why people don't just stretch the trailer tongue:
1. Stretched tongue means crawling up under your camper overhang to couple/uncouple the trailer. That may happen several times with the camper & "heavy junk" staying on the truck for longer periods.
2. They may borrow other people's trailers.
3. The trailer may just fit in a garage with the standard tongue. - burningmanExplorer IISeems many who replied misunderstood the question. This isn't about hitch extensions.
Nobody pulls heavy trailers on four foot hitch extensions without a camper on their truck, ever. It's obvious why not. Its no different when you do have a camper on. People do it because its the store-bought, bolt-on solution and stretching a trailer tongue is custom work. - Kayteg1Explorer IIIn life you will always find something that will surprize you.
I have 2 TC in the same 12' length and similar height of rear bumper.
But Lance has side entry and foldable step cage sticks down few inches.
The cage was bend when I bought the camper and even I straight it up, it did not take long to have it bend again.
I guess that design would rule out long tongue on the spot. - BedlamModeratorExtending the tongue length on the trailer reduces the hitch weight even though that extra length adds material weight to the empty trailer. A longer tongue will make a trailer track inside a turn more than a shorter one. With about any trailer, you want the distance from rear corner of the camper to the front corner of the trailer to be more than half the width of the widest camper or trailer measurement. You need to add at least 1/2 a foot to the length to compensate for uneven ground.
Extending the receiver will swing a trailer wider in turns than without the extension. The outward swing will not be more than rear of the camper but is noticeable. Backing up a trailer using an extension will make the trailer respond quicker to steering input as if it was a shorter trailer due to the extra swing.
Some campers have little hanging bellow bed level and better suited for longer tongues directly connected to the receiver others have a step down to carry generators or propane in the rear wings plus have dump plumbing and generator exhaust hanging even lower. Remember that when taking dips out of driveways, you are also turning and may contact something to the side of the tongue rather than the camper floor.
44,030 PostsLatest Activity: May 05, 2025
