Jay_Pat
Feb 11, 2018Explorer
Hi Pat--
Are you referring to the grab handle/step on tail gates of newer Super Dutys? Yes, Mine is a 2010.
NOTE: My 2003 does not have those NICE features!
1. Did you consider the CargoSlide? Did not know that company existed.
2. Have you gotten close to the 1000# rating to see how it holds up and slides with that weight?
Have never tried to weigh. I do keep heavier on the front end.
3. What is the flat bed made of? Steel They state "Weatherdeck composite" which internet tells me is a foam type of board. Some kind of hard board covered with thin carpet.
4. Are you long bed or short? Long bed. If short, much can you fit in your bed slide? My long bed is rated for 1200 lbs. I use plastic tubs with lids when possible and stack two high.
Thanks!
Pat
Thanks!
Pat
