PA12DRVR
Feb 11, 2018Explorer
Jay Pat wrote:
Hi Pat--
Are you referring to the grab handle/step on tail gates of newer Super Dutys? Yes, Mine is a 2010.
NOTE: My 2003 does not have those NICE features!
1. Did you consider the CargoSlide? Did not know that company existed.
2. Have you gotten close to the 1000# rating to see how it holds up and slides with that weight?
Have never tried to weigh. I do keep heavier on the front end.
3. What is the flat bed made of? Steel They state "Weatherdeck composite" which internet tells me is a foam type of board. Some kind of hard board covered with thin carpet.
4. Are you long bed or short? Long bed. If short, much can you fit in your bed slide? My long bed is rated for 1200 lbs. I use plastic tubs with lids when possible and stack two high.
Thanks!
Pat
I'd almost ditto this:
- 1000# Bedslide that is prolly 10 years old now;
- the surface on mine is some sort of hard board with a hard rubber dimpled surface on top. No wear to speak of, but it does capture the grit, so it's hard to get it "showroom clean" after the aforementioned 10 years.
- I suspect I've exceeded the weight rating a time or two with no ill effects, but I'm always cautious about how I put a load on if the slide is extended
- As noted above, I've acquired several plastic totes (black/yellow, 27 gallon) that will stack two deep and fit under my topper. I can put 4 (not 8) of these in with a bit of room left on the bed for my jack and shovel and a bit of room left above the totes for camp chairs, etc (i.e. relatively low volume / low weight stuff).
- I've almost got my gas can supply revised to only include cans that will fit in the aforementioned totes.
One looses some volume with the bedslide, but more than made up for in convenience.
44,070 PostsLatest Activity: Sep 18, 2026
