JIMNLIN
Jul 06, 2016Explorer III
goducks10 wrote:
Way too early, but the tread pattern is different from the usual patterns.
Much better looking tread pattern with a center rib and two narrow ribs on the outsides help the tire track straight and run cooler than the RH. The HD also lost that rounded sidewall profile. The HD is a new redesigned tire.
I think some tire chain stores and dealers pass along lots of mis information about tires which is taken as gospel especially on rv forums where so many folks are new to trailers and tires.
This from Carlisle new website;
Carlisle Radial Trail HD
We have completely redesigned the industry-leading Radial Trail RH trailer tire for:
Improved tread wear
Greater heat resistance
Increased durability
In real world testing, the Radial TrailHD showed a 10% improvement in tire life over the Radial TrailRH, giving you a longer lasting trailer tire.
Building the toughest trailer tire means we needed to engineer the inside to be as strong as the outside. Every component in the Radial TrailHD was updated to outperform the competition. Every component in the Radial TrailHD was optimized to reduce rolling resistance – extending tire life and increasing durability.
So, whether you use your trailer for work, play or sport, the Radial TrailHD tire is the toughest and safest radial trailer tire on the market giving you increased peace of mind and protection.
