kgard1225's avatar
kgard1225
carrying Atv in short bed truck with TT
Hi all, I am trying to find a way to bring my atv along but the rear wheels rest on the tail gate. I do not have turning clearance with the tail gate down and can't afford a toy hauler !! Any thoughts ??? I was trying to find a half height tail gate but no luck and the atv is too heavy to lift the front up. F-250 TV. Thanks, Ken
  • kgard1225 wrote:
    The truck bed is actually 6 3/4 ft long but I have an auxiliary fuel tank that takes up 18 inches in front. I had considered putting a couple of 2 x 12 boards under both front and back atv tires that should hold the tires. Anybody done that ?
    this will work fine. could also use your loading ramps.
  • I just found this ... Rizerback frame to fit front tires on top of truck bed frame https://static.wixstatic.com/media/7a6a39_b36994ab70284a7e91ce26ecba2a6ccd.jpg/v1/fill/w_3264,h_2448,al_c,q_85/7a6a39_b36994ab70284a7e91ce26ecba2a6ccd.jpg
  • Every truck I've owned I could adjust how much the tailgate lowers using the cables.
    Raised slightly would likely prevent contact.
