JimK-NY wrote:
Maybe a little more practice with the Navy shower. Wet down with a trickle of water while soaping up. Rinse with a low flow. I also time the water heater. It varies a bit with temperature, but generally I need to heat water for 20 minutes and then it will be at the correct temperature so I do not need to waste more water adjusting the temperature. It should not take a third of a tank for two showers. One gallon per shower! You can also learn to economize with dishwashing. I use a dishpan with some warm soapy water and then a quick rinse. Dishwashing takes less than a gallon a day. I have a cassette toilet so it does not use water from the main tank.
Yeah, more practice for sure. Plus everyone else needs to learn as well, but sometimes I can get pretty **** dirty wrenching on a race car and sweating in the suit 4+ times a day so the 1 gallon method may not work every time. I really wish the water level indicator had more fidelity.
d3500ram wrote:
On a 2 week hunting trip in the bush I fill the 30 gallon tank in the camper plus 6 in the water heater and I take two of these:
All that covers my domestic needs... I still bring 10 gallons or so for cooking and drinking.
Those would be great and are easy to stash, but how are you transferring to the fresh tank? I'm trying to avoid pouring. I suppose it wouldn't be difficult to rig up a pump though.
mellow wrote:
I used to carry the 35 gallon on the front rack but moved it to my roof and did away with the 12v transfer pump.
Top:
Front rack:
Mine has a roof rack too, but it's already so ass heavy I don't dare put anything back there. That didn't throw your balance off? Hell, right now the camper looks to be riding nose up in the truck. It makes me wonder why.
