daystrom's avatar
daystrom
CAT scale result and a question
Had my rig weighed at a Pilot/Flying J the other day. These were the results:
Steer 4,880 LB
Drive 5,220 LB
Trailer 6,800 LB
Gross 16,900 LB
I didn't have time to unhitch the trailer and just weigh the truck HOWEVER I have weighed the tongue before using the bathroom scale method and came up with 950 lb.
Based on this, can I assume that the trailer weighs 7,750 lbs? The certified weight of the trailer by the factory 'as-built' is 6,240 lb. Not sure how to come up with the total weight of the trailer loaded up.
Todd
  • Triker33 wrote:
    Go back and weigh without the trailer.
    Perhaps another time. Would need to load the truck up as I was with dogs, kids, wife, etc, etc.
    This weigh was just for my curiosity and thought I could come up with a ballpark trailer weight based on the trailer weight and tongue weight that I had.
  • You need two passes to determine TW
    Truck alone
    Truck with trailer tongue on ball
    A third pass will help determine how well the WDH is adjusted - truck with trailer with WDH.
  • Then your question can't be answered. It's impossible to know without knowing the TV weight alone.
  • It was. Equal-i-zer brand 12,000/1,200 lb bars.
    I also had a full tank of fresh water (50 gallons) at 400lb.
  • Depends, were the WDH bars hooked up? If so, some of that 950 lbs. tongue weight is on the trailer tires and some is on the TV tires.
