Deb_and_Ed_M
Nov 15, 2014Explorer II
Caulking a large gap?? (pictures)
I'm busy removing the old caulk from my '95 Palomino Bronco 1200. There IS some rot behind this front corner - at some point, the clamp was reinforced with a heavy 90-degree metal piece bolted to the side of the box. It's nice an solid. The gap shown was filled with caulk, which had shrunken and possibly could have leaked again, so I scraped it clean.
I plan to remove and re-do ALL the caulk; but was wondering if anyone had a suggestion for the best way to fill this larger gap? Keep in mind this is a $1000 camper - I don't want to tear out the front and do a rebuild. It will live indoors the rest of its life. Where water got in, the wood is soft-ish - but not crumbly. I figure if I can keep it from leaking any further, it will serve its purpose of a half-dozen weekends of camping.
What will fill that gap besides gobs of silicone caulk??
Has anyone used that spray-on "Flex Seal" (as seen on TV?) They show it being used on an RV. Sure would be faster than silicone caulk for the roof seams!
