cubbearExplorerDec 28, 2016CB Radio antennaI understand a CB radio antenna needs to be grounded. where is a good place to mount as camper is fiberglass?
Sam_SpadeExplorerDec 28, 2016BradW wrote:If you use two cb antennas, they use each other as their ground plane.Not unless one is grounded.If both are powered, they use each other as a director......which may or not be effective if there is no good ground.A lot of truckers use an antenna bolted to their wide mount side mirrors.
