downtheroad
Nov 21, 2018Explorer
Let's start here: hopefully not, but you may have a leak causing this. I don't see any staining so that is good.
Push up on the ceiling in the area around this spot and see if it feels soft. Also maybe take a pin or needle and poke a small hole in the wrinkled material and see if any water drips out or if it is wet underneath...
good luck with it.
good luck with it.
