donn0128
Nov 21, 2018Explorer II
First is leak inspection. Then, if its only loose, take the joint piece off, gently using a heat gun pull the paper loose, apply a bit of white glue and push it back. Re attach the joint. At least thats what I would do. Instead of white glue I might use contact cement.
