Crumm
Mar 31, 2015Explorer
Centering Guides 2.0
Back in 07' I built some centering guides for my 96'. They are posted in this TCU University thread There was some interest in people wanting some built but no way for me to economically build them to sell.
This weekend I built a new set for my 2015 F350. Rather than going with steel I switched to aluminum and rather than welding they are all bolt together. Going this route anyone should be able to build a set.
Pictures will basically explain the construction.
The front are Happijac FM-GL9 centering guide locks mounted on a piece of aluminum channel. I have Torklift tie downs so didn't have a crossbar to mount the guides on. The channel is bolted to the front of the bed with five 5/16 rivet-nuts. I used the rivet-nuts as there is no room between truck bed and cab for your hand and the rivet-nuts make for quick removal/installation of the guide. The tool and rivets can be found at Amazon link.
For the rear I used 3/16x1-1/2 aluminum flat bar. Once again I used the 5/16 rivet-nuts for installation. The bar can easily be bent by heating with a standard propane soldering torch or whatever you have. Doesn't take much heat. Wrapped the guides with 1/4" UHMW using stainless countersunk bolts.
Loaded the camper yesterday and they worked great. Anyone should be able to build these as all that's needed is standard hand tools and no welding required.
