Fastbrit
Sep 03, 2014Explorer
The bottom of the camper is made in 3 stages
-3/4 plywood (the holding tanks are on top of this sheet)
-aluminum structure
-and the last part is what you see from the outside consisting of 1/4 sheeting with the black plastic membrane glued on it.
First , did you open the service trap to the holding tanks located in the rear main storage area ( 8 screws) to see if the 3/4 plywood is wet?
Or is it just the black 1/4 plastic membrane that you are talking about?
-aluminum structure
