jaycocreek wrote:
A quick review from Camping world of the champion 3100 inveter having owned a Honda 3000is.
I bought this one last week to take with us last weekend to the lake. I previously owned a Honda 3000i but it was stolen a year ago. Because we don't go near as much as we used to I really didn't want to spend $2,000 + on a generator so I got the Champion. I took it out of the box filled it with oil & gas and it started the first pole. So far so good. My disappointment was that it was no where near as quiet as the Honda. Maybe when there is no load but when the AC kicks in we were all laughing because it was every bit as loud as my buddies $300 Pep-Boys generator. The next disappointment was after running with the AC on for about 45 minutes it kicked off on overload. I shut it down for a short while then tried it again and after only 5 minutes it was useless. I will admit it was 110 dg outside but I had it in the shade not on an extension cord or any of those other mistakes. I did run my Honda all day once on blacktop at a high of 117 dg. The next day it was a little cooler, like 105 dg and it did work fine. I'm assuming that it was the heat and if we are lucky we won't go camping any more in that kind of heat. Overall it is light, easy to move around with the wheels, great having the RV plug built in but I gotta tell ya, It aint all that quiet.I bought this one last week to take with us last weekend to the lake. I previously owned a Honda 3000i but it was stolen a year ago. Because we don't go near as much as we used to I really didn't want to spend $2,000 + on a generator so I got the Champion. I took it out of the box filled it with oil & gas and it started the first pole. So far so good. My disappointment was that it was no where near as quiet as the Honda. Maybe when there is no load but when the AC kicks in we were all laughing because it was every bit as loud as my buddies $300 Pep-Boys generator. The next disappointment was after running with the AC on for about 45 minutes it kicked off on overload. I shut it down for a short while then tried it again and after only 5 minutes it was useless. I will admit it was 110 dg outside but I had it in the shade not on an extension cord or any of those other mistakes. I did run my Honda all day once on blacktop at a high of 117 dg. The next day it was a little cooler, like 105 dg and it did work fine. I'm assuming that it was the heat and if we are lucky we won't go camping any more in that kind of heat. Overall it is light, easy to move around with the wheels, great having the RV plug built in but I gotta tell ya, It aint all that quiet.
Same thing happened to me with a Yamaha generator not running the AC in extreme heat, yet my Honda has worked fine with the AC at over 100 degree's.
I was going to let this go, but I can't. I have owned both a Honda EU3000is and a Champion 2800/3100 inverter generator. The Champion is a little louder than the Honda. But it is no where near an open frame generator, or even a lawn mower. It's close enough to the Honda that if the Champion is too loud, the Honda will be too. As for it's ability, It blips to about half throttle for less than a second and settles a little over idle when I run my 15k A/C on it. It gets hot here too. Today is 109. I should fire it up and cool off the trailer, just for fun.
