beemerphile1
Jul 09, 2014Explorer
GaiaGoddess wrote:
...towing with my Ford Escape....I decided what I want is a teardrop, specifically the Little Guy T@B S model (with a bathroom)! It's only 1500 pounds so I'll be able to tow it with my Escape....
Nope, in another thread you said that you do NOT have the towing package. That means you are limited to either 1,500 or 2,000 pounds depending on the model. The empty trailer is already at or near your limit. Add some accessories like the awning you mentioned plus LPG and battery and you are heavier than the tow rating. Now add 500 to 1,000 pounds of water, food, clothing, and gear and you are substantially over the tow rating.
BTW, you can make improvements to the towing ability but you cannot ADD A TOW PACKAGE, it either came with it or didn't. No manufacturer publishes exactly what makes up the tow package.
Not saying you cannot do it, just be aware that you will exceed the tow rating.
FWIW my tow rating is 1,500 and I regularly tow 2,000 but it is also low profile.
The smaller Aliner or Chalet would be perfect behind the Escape.
44,066 PostsLatest Activity: Oct 04, 2013
