walleyeb1's avatar
walleyeb1
Changing a flat tire
I have a 34 ft tt and had a flat. Even when I pulled the other tire up a ramp about a foot the flat was still on the ground. Added a 2x6 and just barely lifted it enough to change it. What am I missing here?
  • My TT weighs about 5000 pounds. Hitch weight is 800. I carry a one ton floor jack with me. Logic sort of tells me that I should be able to get one wheel off the ground with a ton capacity jack. But I'm a newby, and my logic is sometimes not so logical ;)
    I don't carry one of those trailer aids either.
    Anyway, is a one ton floor jack adequate?
  • That is why I don't have one of them 'trailer aids'....can't get enough height to raise flat tire
    Bottle jack under axle spring perch is ALL that is needed.
  • You're not missing anything. Not all suspensions will allow the flat tire to hang without as much lift as you needed. What does help is lifting the good tire up a reasonable amount, then use a bottle jack to lift your axle with the flat up just enough to change tires.
    Bruce
