time2roll
Jun 20, 2018Nomad
Real benefit if you feel you can't use all the gears much when towing. My truck has an old 4 speed (4R70W) and would barely hold 3rd when towing so basically I had a 2 speed trans. After swapping 3.55 to 4.10 I easily hold 3rd gear and can periodically cruise in 4th (OD). Less effect if you have a newer 5 or 7+ speed transmission. Still if you can only use half the gears it is time for the differential to change.
44,071 PostsLatest Activity: Aug 16, 2026
