dryfly
Sep 16, 2013Explorer
Differential gear lube.
This may be like asking "which is the best brand of oil" but I need opinions. I'm due to change the differential gear lube in my 2005 Dodge 2500. Last time I used Mobil 1 synthetic 75W-90. I should have gone with the 75W-140 since I'm towing but everything has worked fine so far.
I am going to go with the heavier weight this time and am thinking about adding a PML aluminum finned cover to help lower the temps. It also increases the capacity .75 quart.
I see a lot of folks on the Dodge forums using Amsoil and Royal Purple gear lubes. I'm wondering if the Mobile 1 is just as good. Any comments appreciated.
