delwhjrExplorerJun 19, 2018Changing differential gearsWWould like to hear from those that have actually changed their rear-end ratios. Did you get any improvement? Was it worth it? Any pitfalls?
dodge_guyExplorer IIAug 29, 2018Glad to hear it worked out! This is good info. for others that are considering the change.
Related ContentDifferential fluid changeChange Differential Gears to new Ratio?Differential gear lube.differential changeDifferential Service
