Community Alumni
Jun 29, 2016Brake pad outgassing is a non issue these days with modern brake pads. Most manufacturers claim that their pads produce gas minimally under heavy braking. If ceramic pads are used then outgassing is a complete non issue since the pads don't outgas. Brake pads these days are engineered with materials that reduce outgassing under heavy braking. One of the reasons larger pads typically have slots cut into them is to vent heat and what little gas they produce. Now the asbestos pads from days of yonder are a different story. All vehicles have to comply with FMVSS which tests hot performance, cooling, and recovery all at GVWR which is why I find specialized rotors unnecessary. If the trailer's brakes are setup correctly, regular pads and brakes are more than sufficient to stop the combo.
44,056 PostsLatest Activity: Jan 12, 2020
