goducks10
Apr 03, 2014Explorer
What are you towing and what are you using for WD? It may be that you are towing too much trailer or that the tongue weight is too light or you don't have a sway control WD hitch. Just adding LT tires isn't going to help those other areas.
Have you measured the front of the TV prior to and after hitching to see if your WD is set up properly?
44,056 PostsLatest Activity: Jan 19, 2025
