Tystevens
Apr 03, 2014Explorer
sheripoms wrote:
Well,, I was told it would be better and the sway would not be as bad if I had LT tires. Although I just got Brand new tires on the back. Hate to change them but I will if it affects the sway.
Have you towed with your current tires yet? Are you having sway problems? Are you way overloaded to begin with? If no to these questions, just use what you have and see how it goes. We have towed thousands of miles w/ P tires on our Suburbans, no problems. When I replaced the tires on our last Sub, I put LTs on, but I wouldn't replace perfectly good tires unless you are having a problem.
BTW, sway issues are much more likely due to improper loading, hitch height, or lack of an anti-sway hitch than because of the tires IMO. If you're having sway problems, LT tires may 'help' a bit, but aren't going to fix it. We've never had a single incident of sway issues w/ our Subs on P tires.
Good luck!
44,056 PostsLatest Activity: Jan 19, 2025
