JIMNLIN
Apr 12, 2014Explorer III
sheripoms wrote:
Ok, guys,, well we just got back from Indiana. Brought our new Trailer.
Our Tahoe pulled it pretty well , has enough power, that was not any problem. The only problem was that it was pretty windy going through Illinois maybe like 20 mile hour gusts and it wasnt all over the road by no means. But you could feel a little front end sway, especially when a semi came by. It pulled us in just a small bit.
Also I watched when they put the Equalizer 4pt on and they lowered tongue hitch and the P tires really were bulging quite a bit on the sides. Is that normal? I am wondering if I got LT tires if that little sway problem would straighten out?
How much air pressure are you using in those P tires. You should be using the max 44 psi when towing/carrying a load.
44,056 PostsLatest Activity: Jan 19, 2025
