johndeerefarmer
Apr 13, 2014Explorer III
Nick R wrote:
They also make LT tires in a c or d rating. I would look at the d rated ones. you do not need e rated tires. The LT tires have a stiffer sidewall and will firm up your ride. You should not put 80 psi in the tires either. Look at your rims on the Tahoe I believe that 65 psi is the max those rims will support. I had d Rated 35's on previous truck and ran them with 50 psi and was just fine.
I went with C rated Wrangler AT/S. The truck came with P metric Wranglers. I didn't gain anything on payload but got a tire that wasn't so squishy.
44,056 PostsLatest Activity: Jan 19, 2025
