Trailer Aid makes the same model with a very thick piece of rubber where the tire comes to rest. This adds an inch plus to the height of the flat tire off the ground.
cliffy49 wrote:
2oldman wrote:
I guess you take your chances with a)plastic b) harbor freight.
I'm sure they'll be fine.. unless they're wildly overrated and break under load. Do you feel lucky?
Trailer-Aid "Plus" Tandem Tire Changing Ramp, The Fast and Easy Way To Change A Trailer's Flat Tire, Holds up to 15,000 Pounds, 5.5 Inch Lift (Yellow)
So other than this one being a little smaller in all directions, it would be better than the Harbor Freight unit.
Trailer Aid Plus Dimensions (in):7.2 x 6.1 x 25
5.5" of lift5.5" of lift to aid in performing routine maintenance
Shipping Weight (lbs):5---1 Unit
Buy New: $42.95
List Price: $52.26
Harbor Freight dimensions: 35-1/2 in. L x 12 in. W x 8-1/2 in. H
6 in. max lift height.
Product Weight 18.4 lbs.---2Units
$39.99 plus an additional 20% off with coupon.
Not trying to be a smart ***, just don't understand the plastic Harbor Freight comment. Would only carry one at a time but could use the other when I am changing my Chinese tires for Goodyear endurance at home. Not to mention any other work at home where they could be used.
