valhalla360 wrote:
GrandpaKip wrote:
The tires on our camper are 3.5” apart and the Trailer-Aid works great. I don’t really understand the frame twisting comment. The trailer is sitting just a few inches higher on one side, same as it would on a sloped road.
A simple solution to the changing of tires is to have a spare set of rims.
I was referring to the Harbor Freight ramps. I believe those are around 8" high if they are similar to the ones I'm familiar with from work on cars.
If it's a well built trailer, the frame will likely take the twisting but still not good for it...of course not all trailers have the strongest frame design. More likely the issue is if your overhang clearance is marginal, it could hit the truck bed.
Ah. I wouldn’t want to raise it that much.
