BFL13
Sep 11, 2020Explorer II
HioSSilver wrote:`
Just talked to randy. He recommended the magnetek 8300 45tcru. So i ordered that.
Thanks for the replies.
IIRC that unit has a Parallax 44xx TC in it, which is single stage (useless) without the separate TC gizmo that you add to it. So call back and make sure you are getting that gizmo!
I had a 4455TC years ago and the gizmo that you need to make it do anything useful, so I remember that. It has a long wire wth a ring terminal on a temp sensor that goes onto the battery post.
The trick is to find a route for that wire from the converter location to the battery. Can be a problem!
You could avoid all that by just telling Randy to send you a Boondocker instead and save about $50. :(
