BFL13
Sep 11, 2020Explorer II
You could just cancel the order with Randy since he is being a nuisance for some reason ( he is not always)
I had a 6300 and replaced it with a simple PowerMax deck mount. (Randy's Boondockers come from PowerMax) You do need to jumper the two pos lugs on the 6300's fuse panel so both sides now work from the single pos wire from the new converter---no big deal)
You were happy with $200? Check this out.
https://www.boatandrvaccessories.com/products/powermax-pm3-45lk-45-amp-12-volt-power-supply-with-led-light
Good price and it also has an adjustable voltage mode so you can do 16.2v equalizing if need be (per Trojan specs), plus leave it in 3 stage mode for normal times.
